(HELP)Number modify automatically,is there any way to achieve this?Thank you
2299934
2299934
When I delete the selected Symbol from the floor plan in Plan View.dwg,the corresponding quantity on System drawing.dwg will change automatically(or "re" fresh). Is there any way to achieve this?If you are able to achieve this, please contact me. I sincerely appreciate it.
3wood
Command COUNT can do this.
3wood
In the count window, click "Insert count field" button and insert a field.
Then you can copy its content into a Mtext.
