Help needed ASAP.
Help needed ASAP.
No aplicable
When I receive drawings from another source (another architect, designer, etc) that is in a newer version than 2010 I have to convert them in True View which usually is not a problem. However, I am receiving some drawings where items and texts are jumbled and do not display correctly. I have tried to download the object enabler (it was in German) but that did not help the problem. I am desperate here trying to get a drawing package out. Can you please help. Thank you so very much
0 Me gusta
Responder
Soluciones aceptadas (1)
346 Vistas
2 Respuestas
Respuestas (2)
Alfred.NESWADBA
Solución aceptada
How can we know which text objects you are referring to?
Object enabler for which product?
I see a product "VisionREZ" from company "ITWBCG" as message in the proxy-warning, but that's just one object.
It also looks like AutoCAD Architecture or maybe MEP was working on that drawing.
And I'm missing the XREF :cara_guiñando_un_ojo:
I have now opened your drawing with AutoCAD 2017, run command -EXPORTTOAUTOCAD to DWG-2010 format ... opening this drawing shows the same text as your uploaded drawing (or I missed something).
Please find the exported dwg attached.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
0 Me gusta
No aplicable
Alfred,
Thank you so much for reaching out. I am a bit confused that you are not seeing the objects I am. It must be that Architecture and MEP is not compatible with my AutoCad. I just have not had any problem in the past. Also I am assuming by your comment that the object enabler is not what I need. It is just that when I open the drawing a screen comes up telling me objects will not be displayed properly and to download the enabler
The exported drawing you sent has saved me!! Converting to 2010 did the trick.
Again, thanks so much for reaching out.
0 Me gusta
