Help Installing Pipe Fittings Script
08:11 PM
Hello good evening I have downloaded a demo pack of Pipe fittings because I cant find any inside the Autocad 2014 Software that can be used for Fire protection and plumbing...I followed the instructions and I still can not locate the fittings. If you know where I can get some good pipe fitting libraries please point me in the right direction I will greatly appreciate the favor. these are the demo pipe fittings I downloaded http://www.cadtoolsonline.com/blocks.htm here are the instructions. Instructions A.) Type SCRIPT in AutoCAD's command line, press the Enter button. The Script dialog box will appear. Click on the Browse button. B.) Browse to the folder PIPING4PACK-CTO-DEMO located on your computer's C: drive. Select it, then click on Open. C.) Three folders will be displayed... Select the appropriate folder for your version of full AutoCAD. Click the Open button. D.) Two install scripts will be displayed... Select the appropriate install script for the drawing units you use. Click the Open button. E.) Allow a moment for the menu to load. "Piping 4 Pack (units) - DEMO" will appear next to Help when it's complete. The demo is now ready to use. Please Help. P.S. Thank You For Your Time
