Help!! I am struggling to draw sectional front view, top view and side view of bevel gear support on AutoCAD. I need it as 2d and not 3d. anyone can help
WJB_24
Observer Observer
WJB_24
Observer
Observer
 I am struggling to draw sectional front view, top view and side view of bevel gear support on AutoCAD. I need it as 2d and not 3d. anyone can help please.
Maybe you have done It or you can show me or even a tutorial can do please.
Thank you!
Washingtonn
Where are the section cuts to be made?
WJB_24
Observer
Observer
sorry my bad! I have attached the correct picture. I basically need to produce different views on autocad as a drawing with the dimensions.
Washingtonn
It appears you already have the top view and the side view from B which leaves the section view A-A.
The section view can be thought of as cutting the object at the plane A-A and keeping everything in from the plane and beyond (direction of the arrow). The cut surfaces are then hatched to show them as cut. The larger three holes are no longer shown dashed as the hole edges are now visible.
Note that the picture does not correctly indicate the connection of gussets to the lower rounds - are they tangent to the 38 diameter or do they terminate above the centerline as shown?
jkuzmaDYXFG
REVIEW
