Help finding and removing unwanted dimstyle and text style. I can't find the objects where they're being used.
I am really struggling with purging the last few unwanted dimension styles and text styles from the new template I am setting up. There are 2 dimension styles and 1 text style that I am unable to purge. Looking in the non-purgable objects menu:
- the 1st dim style is being used by AEC_DISP_PROPS_STAIR_PLAN, AEC_DISP_PROPS_STAIR_PLAN_OVERLAPPING, AEC_DISP_PROPS_STAIR_PLAN_100 and AEC_DISP_PROPS_STAIR_PLAN_50. I managed to find the stair plan deep in the style manager under architectural objects. Which is really strange as we are not architects, we do no design work involving stairs whatsoever, so I have no idea what this default style is, how it got there, or why it is there. I went through the style manager and changed all the dim styles to the one I set up, and yet I still can't purge this dim style. It still shows up as being referenced as above. I also can't purge or delete this stair style. It's the only architectural object in the drawing. So, if you know how I can completely remove it that would be ideal. If not, I would be happy with just removing the dim styles from it so I can delete the unneeded style.
- the 2nd dim style is being used by AEC_DISP_PROPS_DIM. I have no idea what this is, or where I can find it. I have gone through the settings tab in toolspace, item by item and made sure that all the old dim styles are not referenced anywhere. I've tried using the styles purge in manager tab, but that didn't work either.
- the text style is being used in AEC_LABEL_COLLECTOR_STYLE. Similar to above, I have no idea what this is or where I can find it. I wasn't able to find much on google as to what a collector is, just that it was related to parcels and importing data. Again, going through the settings tab I've checked every single item to make sure it's not referenced anywhere and found nothing.
I can only attach 3 images, so here's a link to all 4 screenshots I took, if they'll help.
https://imgur.com/a/dimstyle-text-style-non-purgable-mSDtYr6
Thanks!
