Hello everyone,
I am trying to export lines (or polilines) to an excel spreadsheet for further manipulation.
what i basically need is having in the same row the following five (or 7 in case Zaxis is shown by default) cells with the following information:
1.index 2.Xvalue(1st point) 3.Yvalue(1st point) 4.Xvalue(2nd point) 5.Yvalue(2nd point)
there is no "Z" (or rather I dont need the Z values as the images I have to work with are 2D so Z=0 for all points)
I have checked the forum for help/hints but so far nothing seems direct/automated enough... most posts were regarding the use of _LIST (then copy/paste) and Click2Xls. These were helpful but not good enough since I have to do that for files with hundreds (if not thousands) of lines/polilines. To give you a better idea: imagine a huge masonry wall with lots of squares and rectangles and the information i need are the contact surfaces/lines.
Any idea on how to do that with a faster, and safer aswell, method? meaning that while clicking vertexes for coordinates I sometimes ended up forgetting to click all lines and was left with an imcomplete model.
Thank you all in advance,
Adrian
