helix alignment
helix alignment
helix alignment
Hi, everybody!
I have an issue with helix alignment.
The file is attached
When I use alignment function is changes the shape of helix.
The helix is
Base radius 37.5
Top radius 0
Height 20
Turns 0.2
I perform alignment as follows
I choose align function
I choose first source point top of  the helix, I use the same point  as destination point.
Then I choose second source point the center of green circle
Then I choose second destination  point the center of red circle.
How to avoid changing helix?
The problem may be in the fact that I can't set the same point of view in order to estimate the origin and the result,
but as far as my eyes see the resulted helix is not the same as the origin one.
All ideas are appreciated!
Thank you!
parkr4st
both have identical properties.  where are you aligning from and to?
Hi!
Thanks for reply.
I have attached the file.
Left figure is the original and the right figure is the result.
My  steps are described in my prevoius post
ThankS!
parkr4st
two options   add the third alignment point at the center of the large circle source and destinaiton
or
Rotate; select helix, center of the large circle, and center of the red circle
dave
Yeah!
It works!
Thanks!
