Hebrew text not displaying correctly (reversed/garbled)
hforsan3032017
hforsan3032017
Community Visitor
Community Visitor
Hi everyone,
I’m a student, and I received an AutoCAD drawing file from my college.
When I open the file on my computer, the Hebrew text appears incorrectly (it looks reversed or like random characters instead of proper Hebrew). However, on the original computer where the file was created, the Hebrew text displays correctly.
Has anyone encountered this issue before?
Could it be caused by missing fonts or text settings?
What would be the best way to fix the Hebrew text so it displays properly?
Thanks in advance!
see the screenshot.
TheCADnoob
There have been several variations of this (or similar) issue.
I would start by checking to see if you have the font installed
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Fonts-not-being-di...
First, verify whether the font is missing or installed
  • Fonts are located in the following folders:
    1. C:\Autodesk\AutoCAD 20xx\Fonts
    2. C:\Users\[username]\AppData\Roaming\Autodesk\AutoCAD 20xx\[release]\enu\Support
  • The default substitution font for AutoCAD is Simplex.shx. To show which font AutoCAD is substituting a font cannot be found:
    1. Open a drawing.
    2. Press F2 to open the dialog.
    1. Opening an AutoCAD 20xx format file. Substituting [simplex.shx] for [font_name.shx]. Regenerating model.
CADnoob
rosie_lucas1
Hello @hforsan3032017,
Have you had the time to review and try the guidance and steps that @TheCADnoob provided?
If it helped please consider clicking the "Accept Solution" button. Doing so helps others in the community find answers to similar issues.
If your question still needs more attention, feel free to reply here with an update. This way, other members can jump in with further suggestions or guidance to help you move forward.
All the best,
Rosie | Community Manager
