Having trouble copying a block with attribute data to another drawing.
No aplicable
I have this attached block which when i copy it to another drawing, all the attributes within it turn to x's. I have about 50 drawings that need this done, and I'd really rather not copy the attribute data from every old drawing to every new drawing.
0 Me gusta
Responder
337 Vistas
4 Respuestas
Respuestas (4)
jtohill
The information is sheetset and sheet specific custom information. when you copy from one sheet to another, is the second sheet part of the sheetset and have you set up the custom information for the second sheet in the sheetset manager?
0 Me gusta
No aplicable
It doesn't look like they are a part of the same sheet set.
0 Me gusta
jtohill
If you are not using sheetset manager, then you can just modify the attributes to what you want it to say. If you are using sheetset manager then you would have to modify the sheet custom fields in sheetset manager. I use the manager to set the sheets up and it would bring this file you have from a template file with this in paperspace. Not sure how you are working with this file so will wait for the correct response.
0 Me gusta
jtohill
Try moving this to paperspace and right click on the layout tab and import layout as sheet to move into sheetset, if you are using sheetsets.
0 Me gusta
