Having problem with the new printer. Prints lines lighter then the old one. Help please!
peturh
peturh
We just bought a new printer, Canon imageRUNNER  Advance DX (C3835i) and the plot styles are printing lighter then our other printers. Can it be fixed in settings in AutoCAD ?
Printing in other programs are normal and it seems that is only printing/plotting in AutoCAD that lines come out lighter.
0 Me gusta
Responder
Soluciones aceptadas (2)
345 Vistas
4 Respuestas
Respuestas (4)
Valentin-WSP
@peturh ,
Start with the suggestion from this link:
Also, plot a PDF - using the AutoCAD DWG to PDF.pc3, and make sure to check "Plot object lineweights".
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
Emilio Valentin
0 Me gusta
peturh
Thank you for quick response.
I already saw this solution and it does not help me. All the settings work perfectly on the plotters and the older printer.
I was hoping that there was some settings to adjust each printer to darken or lighten the print styles.
0 Me gusta
Valentin-WSP
Solución aceptada
@peturh ,
If you have the same issue after printing a PDF, consider adjusting the printers DPI setting:
Otherwise you may need to copy (or create) your current AutoCAD CTB and modify to your desired output:
Or contact a Canon technician.
Emilio Valentin
0 Me gusta
pendean
Community Legend
Community Legend
Solución aceptada
@peturh wrote:
...All the settings work perfectly on the plotters and the older printer....
Different printers/plotters can have a dramatically different output too: if all the other tips shared are not working for your needs you'll most likely end up creating custom plotstyle tables and LWEIGHT settings just for this new device.
Be prepared.
0 Me gusta
