HAVING PROBLEM IN SCALING IMAGE
No aplicable
Hi, I've changed to a new pc so I've reinstalled my AUTOCAD. Then I realized I couldn't scale image like how I normally scale it. The blue vertex at the image is gone (as shown in the screenshot). May I know how to get it back like the second screenshot? THANK YOU ~ Emoticono feliz
0 Me gusta
Responder
656 Vistas
10 Respuestas
Respuestas (10)
imadHabash
>> ...The blue vertex at the image is gone <<
i suggest to change GRIPS system variable to 1 or 2 .  >> Click <<
Command: GRIPS
Enter new value for GRIPS <0>: 2
Imad Habash
0 Me gusta
No aplicable
I've tried and the GRIPS value are already (2). Emoticono triste
BTW THANKS for your reply ! Guiño
0 Me gusta
imadHabash
if   GRIPOBJLIMIT system variable = 0 . please change it to another positive value ( The valid range is 0 to 32767 ) .
Hope it's help ... :cara_con_una_leve_sonrisa:
Imad Habash
0 Me gusta
No aplicable
The problem is still there Emoticono triste
Is it the problem regarding the settings in my AUTOCAD?
0 Me gusta
Shay.Gaghe
Set Imageframe to 2
Using Autocad 2018, Autocad Architecture.
Please accept as solution if i solved your problem
0 Me gusta
imadHabash
if not fixed yet ... would you attache here the image itself for checking please ( with the dwg file ) ?
Imad Habash
0 Me gusta
No aplicable
I've attached the dwg here Emoticono feliz
0 Me gusta
No aplicable
Thank you for your help.
But it's still the same Emoticono triste
0 Me gusta
Shay.Gaghe
your drawing act normal
i can see the grips and scale
try to reset autocad
go to Start> autocad>reset
0 Me gusta
imadHabash
i can either see the grips and can scale the image .
Imad Habash
0 Me gusta
