Unable to hatch when opening up an already existing dwg file. But when I make a copy of the file I am able to hatch without any problems.
Well, you have your solution - carry on working in the copy, and supersede the old non working version. If this is a recurrent problem, can you give us some more information so we can try to reproduce the error:
1. No it is only the files that my coworker had converted from Visio to AutoCAD.
2. No I can not share the file.
3. I am able to click the hatch command, and pick the color I want but it does not apply to hatch to any part of my drawing.
4. I am just copying and pasting the drawing into a new drawing.
You are copying and pasting to a new drawing, not just copying the file.
In the original file, check the FILLMODE value. If it is 0, then the hatches are being created and just not showing up. Change the FILLMODE to 1 in the original drawing and see if any hatches appear.
Note: FILLMODE also affects the way polylines that have width appear. With FILLMODE = 0, polylines with width will appear as a double line:
