HATCHes does not apply
szocskatalin99
Observer Observer
szocskatalin99
Observer
Observer
I can select the area, I see the preview but when I press Enter, everything disappears. Without any error message.
_AUDIT found nothing, I see the previous hatches, lines are closed
The lines that surround the area are not on the same layer. Would that be the problame?
imadHabash
You may need to check your layers status  .
Imad Habash
szocskatalin99
Observer
Observer
I just see that if I use a pattern, that works. If I want to use Solid option, it does not work
imadHabash
check from FILL command = ON . then type regen .
Command: FILL Enter mode [ON/OFF] <OFF>: ON
Imad Habash
szocskatalin99
Observer
Observer
It was turned on.
imadHabash
what about FILLMODE (System Variable) = 1 . don't forget to regen .
Imad Habash
szocskatalin99
Observer
Observer
the value was 1. Currently found a "pattern" that has no pattern, I will use that this time, I have deadline tomorrow. However, thank you a lot for the help!
