Hatches below not showing through attached raster image
morganism3
morganism3
Hello, and thank y'all in advance!
Here is what I'm doing / my problem:
Ok, where I work, we have these massive logs with grids and lines and such. We have to weird-shaped areas of the log. I make a matching outline of the area of color, hatch it, and attach the log as a raster image over it, with these options: brightness 50, contrast 50, fade 0, show image, background transparency. In one file I have multiple logs over muliple patches of color. I have all the logs (raster images) on the same settings, yet one will not show the colors underneath. Any thoughts?
john.vellek
HI morganism3,
My first suspicion is that the issue is draworder related.  Is it possible to attach some files for me to look at? I look forward to working on this issue with you.
Please hit the Accept as Solution button if my post fully solves your issue or answers your question.
John Vellek
john.vellek
Good morning morganism3,
I am checking back to see if my post helped you with your problem. Please add a post with your results so other Forum users can benefit.
John Vellek
morganism3
Sorry I didn't get a chance to log back on sooner. After searching with a coworker, we realized that the issue was transparency color. We clicked on the grid, PROP, clicked the ... by transparency color, which was set to black, and clicked in a spot of white on the grid. This fixed the problem.
