hatches and system variables
Marlec
Message 1 of 8
Marlec
hi!
I have a problem with my hatches... and I can't find wich variable is involved...
I started helping on a project in metric. at first glance I have all the same variables set-ups of my co-workers...
measurement = 1
units = decimal
insertion scale = millimeters...
the problem is when hatching or editing hatches, I need to scale them  x25.4...
Is there a variable that prompt CAD to use acad.pat instead of acadiso.pat (or the other way around?)
Replies (7)
Message 2 of 8
Patchy
Could be this:
Message 3 of 8
pendean
Community Legend
Community Legend
MEASUREMENT/ MEASUREINIT are the variables. Your file probably started it's life in the wrong setting.
INSERT your problem file into a working template file that has no such issues, EXPLODE, then test it with a new hatch to see if the problem goes away. I suspect it will. SAVEAS and use this new file instead.
Message 4 of 8
Marlec
@Patchy
Nope... measureinit = 1 at all stations...
Other hints?
Martin
Message 5 of 8
Patchy
How about -DWGUNITS convert it to metric system first.
Message 6 of 8
Marlec
@Patchy
If I entered something wrong... it didn't work...
3. Millimeters
2. decimal
Linear display format <4> ? what's that?
@pendean
Tried it... not worhing either...
But the new file I used to insert the problem file is a custom made office metric Template with a dwg extension instead of dwt file...
I think I have to change/remove a lot of parameters just to make a new "virgin" drawing...
Message 7 of 8
Marlec
No new suggestions ?
Martin
Message 8 of 8
Patchy
Use qselect, isolate hatches and change the scale, see if it changes anything.
