Anuncios
Hatch won't work
Jeanettebrooks84
Hatch won't work
Jeanettebrooks84
Hi
I have done 2 opstalt in a drawing and i want them both to have the same wall (Hatch)
One i got done very easy but the other one wont do it.
After a while it says "A closed boundary could not be determined, there might be gaps between the boundary objects, or the boundary objects might be outside of the desplay area"
I have tried, what i think is everything, and i can not get it to work.
Hope someone can help me, Thanks
0 Me gusta
Responder
Soluciones aceptadas (1)
1.058 Vistas
12 Respuestas
Respuestas (12)
imadHabash
I suggest to follow this link that may help . >> Click <<
Imad Habash
0 Me gusta
Jeanettebrooks84
I think i have tried all the things there is in the link. (As much as I can as im pretty new, but i do as it says)
:cara_con_los_ojos_en_blanco:
0 Me gusta
Kent1Cooper
Solución aceptada
Even in the one that works, these pieces of the Hatch pattern suggest that the water closet shape has "leaks" in it:
They may not contribute to the other problem, but there are probably similar water-tightness deficiencies elsewhere.  Read about the HPGAPTOL System Variable.  But it's probably better to find the gap.  When you get that message, does it not show you where the problem is, with red circles like this [here with a deliberately over-obvious condition]?
Kent Cooper, AIA
0 Me gusta
Jeanettebrooks84
No it do not show red circles, that would had been smart if so.
I have tried to removed the toilet to see if it was the problem as I too saw that the lines went through.
But still it wont do the hatch. I have tried to make my edge red and zoom super much in to see if I have a gab and there was nothing to see. :cara_asombrada:
0 Me gusta
pendean
Community Legend
Community Legend
@Jeanettebrooks84 share that DWG portion here for everyone lese to try it.
Jeanettebrooks84
how do I do that?
0 Me gusta
DumR0
0 Me gusta
Jeanettebrooks84
Here is my drawing
0 Me gusta
Jeanettebrooks84
Ok, i found out how to :cara_con_una_leve_sonrisa: I should be down below
0 Me gusta
Jeanettebrooks84
I have now followed the link and done as it says, but i dont get the red circles... ?!?
0 Me gusta
Jeanettebrooks84
I have now followed all the tips and links i have been sent and now I get a new massage when i try to hatch.
I have added the picture of what it says, plus I have added a dwg file of the project.
Hope someone can help me with this silly problem
0 Me gusta
Kent1Cooper
Move the flower arrangement out of the picture -- that has a huge amount of complication for evaluating a boundary.  [And who would put a flower arrangement there, anyway?  Is there even a surface on the top of a shower enclosure wide enough to hold something like that?]
And I suspect overly-complex things like the shower head are similarly part of the problem:
That has way too many openings to "reach through" and try to find some closing-off boundary within.
Kent Cooper, AIA
0 Me gusta
