Anuncios
Hatch with transparency plotting issues
No aplicable
Dear AutoDesk community,
I'm trying to print a document that has a hatch with transparency, but there's a difference between the preview on the screen and the result, see attached documents. I use AutoCAD 2017 for Mac, the hatch consists of a linear gradient with two Pantone colors with transparency at 60% and on the page's set up the "Print transparency" box is checked.
Looking forward to hearing your answers receive my regards,
Alvaro
0 Me gusta
Responder
446 Vistas
3 Respuestas
Respuestas (3)
Johanna_Esteban
Hi @Anonymous,
Can you please share your file ?, I will check if the same happens on my pc.
Johanna Esteban
Autodesk Expert Elite | Autodesk Certified Professional | AutoCAD Customer Council (Beta Tester for Windows & Mac)
¿Te ha parecido útil este post? ¡Dame Kudos! :cara_guiñando_un_ojo:
Si ha sido resuelta tu inquietud, selecciona 'Marcar como solución' para que otros usuarios la encuentren fácilmente.
0 Me gusta
No aplicable
Dear Johanna,
Here you have the file and thank you for taking your time.
Best regards,
Alvaro
0 Me gusta
Alfred.NESWADBA
I guess you are referring to layout C512, is that correct?
For me the PDF looks ok (please find attached), however ...
  • I don't have a Mac, so I used the Windows version, and used the device "AutoCAD PDF (General Documentation).pc3"
  • I don't have your plot style "V_Arquitectura_1.50.ctb" ... so my system can't see these settings.
As you are using Mac and the print to PDF is different working on a Mac compared to Windows I would recommend to ask in the "AutoCAD for Mac" forum >>>there<<<.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2025
(not an Autodesk consultant)
0 Me gusta
