Hatch - weird behaviour
w64bit
w64bit
I attached a DXF with a hatch with a weird behavior. If it's selected, it doesn't have a closed boundary.
Is there any way to fix the existing hatch, other than I draw it again?
0 Me gusta
Responder
372 Vistas
7 Respuestas
Respuestas (7)
Alfred.NESWADBA
Sorry, No (based on my limited knowledge).
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
0 Me gusta
cadffm
Absolutely normal (not good, but normal).
1 Hatch without associated bounfary objects
 also
2 Hatch created by using open shapes
Not really good, but nothing "wiered".
Test it: use LINE and draw a big "V", now create a hatch by using the SELECTION method, not the pick- method.
Sebastian
0 Me gusta
cadffm
>">> Is there any way to fix the existing hatch, other than I draw it again?"
You can re-create the boundary object
HATCHEDIT
and the use JOIN
and set the CLOSED property to your polylines
Thats "near to" the solution you asked for.
Most more important: WHY the xxxx is your file saved as R14 Format???
Sebastian
0 Me gusta
Alfred.NESWADBA
"near to" may or may not be, the missing segment could be just one line, it could also be an arc or multiple segments that are missing now, so we don't know how the open part was connected.
- alfred -
Alfred NESWADBA
0 Me gusta
cadffm
"so we don't know how the open part was connected"
It wasn't connected or better: It wasn't important for the hatch.
"LINE or ARC" This is known
Ok, perhaps it was a polyline or a circle, but the important part for the hatch
(the part what was part of the boundary) you can re-create by this way.
@w64bit
sample attached
Sebastian
0 Me gusta
w64bit
Thank you all.
One more thing. For an open polyline it is possible to set Closed=Yes to close it.
Is there anything similar for hatch?
0 Me gusta
cadffm
No,
then you really need to create a boundary and create a new hatch.
Sebastian
0 Me gusta
