hatch transparency
hatch transparency
hatch transparency
The hatching I have used needs transparency. So I make it transparent and exit the hatch editor. Then I save my work and exit autocad. When I re-open my autocad file all the transparency changes back to 0.
Its the oddest thing my whole office has seen. I work on Autocad 2018.
I have added a picture and dwg
cadffm
"Transparency" was not available in the 20 years old Program version 2000.
Also associated dimensions, also not available -  layer overrides, annotation feature and more more more
Solution: Work in the native file format: dwg2018
If you need the dwg2000 format, you cannot use transparency (the format is not prepared for transparency)
Sebastian
imadHabash
i suggest to make your transparency in hatch editor as Bylayer then from Layer command dialog check and change Transparency tab .
Imad Habash
Thank you
I have changed the format and it worked
