HATCH TRANSPARENCY PROBLEM
Hi all,
I am using autocad 2019:
I have an issue on hatch transparency, Here is the scenario. I have a solid hatch and I set it to 50% transparency, it works perfectly fine, when i save it and close the App. Then when i open the CAD file and try to edit some lines all my solid hatches become no transparency. Is there any settings i need to do so i don't need to set transparency of my hatch every time i open it?
Below image is the sample showing my issues.
1. Original drawing with 50% transparency
2. Showing 0% transparency
IMAGE COMPARISONIMAGE COMPARISON
Thanks and regards,
Maynard
ennujozlagam
TRANSPARENCYDISPLAY is on (1).
nrz13
Does it still print/print preview as intended?  What does the Properties Palette report for the transparency of the hatch object before and after saving?  As already suggested, your TRANSPARENCYDISPLAY variable could be resetting for some reason.
As a work-around, you could try leaving your hatch with no transparency and put the entire hatch on a layer with 50% transparency.  It's hard to tell exactly what's going on without the drawing, so if you can share that it might help.
Work:  AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-8700K, 32GB RAM, Samsung 960 Pro SSD, AMD Radeon Pro WX 5100, 3 Dell Monitors (3840x2160)
Home: AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-11700, 64GB RAM, Samsung 980 Pro SSD, NVIDIA Quadro P2200, Dell Monitor (3840x2160)
