Hatch-settings screen do not give an option for 'OK'
I am trying to use Hatch feature. I drew a rectangle and went to Draw/Hatch, it doesnot give me anything to choose from the command prompt but take me to the settings screen but the 'OK' button is not highlighted. So whatever designs or changes that I select in the settings screen, I cannot click on the
'OK" button. It is not there. So I am not able to use the 'Hatch' command. see the screen print.
I am using 2017 version.
Thank you.
Alfred.NESWADBA
"OK" is not starting anything, to place a hatch from that dialog you either need to click on "Add: Pick points" or "Add: Select objects".
("OK" is only used for editing existing hatches)
SCNR: If you would not use the (outdated) classic interface you even would not need to start that dialog, the hatch command would then directly ask for a point or object. 😉
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
