HATCH pattern scale problem in any drawings
Lucas_Defalco_Marcomini
Message 1 of 13
Sometimes, when i change the hatch scale, i have to insert a scale lesser then the usually scale, and i have more than one hatch patterns, with the same scale in the properties, but different scale if you look them(as the image bellow). Usually i COPY, and PASTEORIG for another drawing and this is solved.  Is there any solution to fix this problem in the same drawing? I'm not using annotative hatches.
Lucas Defalco Marcomini
Replies (12)
Message 2 of 13
Patchy
If they are different between 2 drawings, could be 1 is Metric and the other one is Imperial, eventhough they show same scale.
Message 3 of 13
Thanks for the answer.
I am use the same template, with metric system, for the booth drawings.
Message 4 of 13
Patchy
Put a circle around the 2 hatches and attach your drawing, let's see why .
Message 5 of 13
Thanks for the Help.
The two hatches are insided on red revision Cloud.
Message 6 of 13
pendean
Community Legend
Community Legend
Change your hatch angle and see what happens: use PROPERTIES
Message 7 of 13
If i change the angle, all patterns are displayed on the same scale, but the hatch spacing is greater than the normal, may i fix this?
Message 8 of 13
Patchy
Have you tried MATCHPROP instea of changing the scale.
Message 9 of 13
Yes, first of all i've tried use MATCHPROP, then, i changed the scale and pattern by PROPERTIES, so, using the booth, the scale is not normal.
Message 10 of 13
wispoxy
Here are some comments I found related to your issue.
"We had this problem at our office as wel. It's probably caused by 2 computers using different hatch pattern files, or by mixing up imperial and metric hatch patterns files.
We fixed it by copying acadlt.pat and acadltiso.pat from 1 pc to all other computers in the office, to make sure we all used the same pattern file. This will also prevent the 'reading hatch pattern error' ( ?) from occuring.
It still comes up when opening old files and files from third parties do. "
MEASUREMENT and MEASUREINIT are set to 1 = metric but the current dimension style is architectural inches
AutoCAD Hatch Scale Problem
Problem
You have two drawings using the same hatch pattern name, to make the appearance match, one drawing has to have the hatch pattern scale approximately 25 bigger than the other.
Solution
AutoCAD has two hatch pattern files.  acad.pat (imperial) and acadiso.pat  (metric) The pattern that is used is determined by the setting of  MEASUREMENT variable when the pattern is first inserted.
MEASUREMENT 1 uses acadiso.pat  (metric)
MEASUREMENT 0 uses acad.pat   (imperial)
It would be good practice to set all your template files to the same setting
Below are extracts from the pat files. note the ratio between the files is 3.175/0.125=25.4, (1 inch is 25.4mm)
Acadiso.pat
*ANSI31, ANSI Iron, Brick, Stone, Masonry
45, 0, 0, 0, 3.175
Acad.pat
45, 0, 0, 0, 0.125
To update a pattern (option 1)
Set the MEASUREMENT variable to the chosen setting, select the hatch, right click pick properties pick scale, change value to anything and change it back again, this forces it to update and refer to the correct pat file.
MEASUREINIT Controls whether a drawing you start from scratch uses imperial or metric default settings.
Message 11 of 13
Thank you so much Andrew!
The problem has been fixed! Thanks for everyone who helps on this topic, this was very useful!
Message 12 of 13
wispoxy
Glad to see your problem was solved 🙂
Message 13 of 13
mohamedashrafog53
Observer
Observer
Hello Andrew, I know this discussion could be a bit old, but I had the same issue with hatch scale and your solution helped alot, I just wanted to thank you for making it clear 🙂
