HATCH PATTERN LAG
HATCH PATTERN LAG
No aplicable
I have been dealing with ( always!) every time I click a hatch pattern the autocad freezes or lags.
Is this something I can get rid of? Is that because of a bad install or need more ram or better graphics card?.
Mind you I have AUTOCAD on many pcs and no matter what version I have or age of the pc it still FREEZES.
Sometimes it makes AUTOCAD crash. Can someone please give me some advise so I can correct this issue.
THANKS IN ADVANCE!
0 Me gusta
Responder
279 Vistas
1 Respuesta
Respuesta (1)
Alfred.NESWADBA
Do you have the property window open? If yes, do you see the same lag when you close the property window before you select the hatch?
Does the same happen in a new drawing with a rectangle hatched (using ANSI31) too?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
0 Me gusta
