Hatch not visible when in a different layout.
chris_youngAE8TB
chris_youngAE8TB
On my model layout, I have a hatch area (not on its own individual layer) that is not showing up on a different layout.  Nothing is frozen, transparency is 0.  What other values should I be looking for/at?  AutoCad 2024.
Replies (7)
paullimapa
Make sure vplayer is thawed for that layer in that vport
Paul Li
IT Specialist
@The Office
cadffm
VP FREEZE (on = invisible), but you already said it isn',
or you are using anothing annotation scale in that viewport, that's the other possible reason.
Sebastian
chris_youngAE8TB
VPLAYER is thawed...that hatch is on the same layer as the green directional arrows (which are visible.)
Please explain the anno scale for that viewport...what should I be looking for?  Not extremely familiar with it.
pendean
Community Legend
Community Legend
@chris_youngAE8TB You're going to have to share that DWG file here please.
paullimapa
Is your hatch annotative?
What happens if you disable annotation scale on the hatch?
Anno scale for vport typically should match with vports display scale
Paul Li
IT Specialist
@The Office
chris_youngAE8TB
That was it!  Thanks.
paullimapa
You are welcome…cheers!!!
Paul Li
IT Specialist
@The Office
