AutoCAD Forum
Hatch lines disappear when inserted
4 REPLIES 4
1036 Views, 4 Replies
I created a custom hatch pattern and when I insert it several lines disappear. But if I explode the hatch they reappear. Any thoughts?
4 REPLIES 4
jayhar
Hi @Anonymous
HPMAXLINES set at a maximum of 10,000,000
Fillmode ON
Jayhar.M.J
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly.
in reply to: jayhar
Thank you for the response. I've tried that with no results.
cadffm
Please start a new file,
use command: _RECTANG for a simple shape
near to 0,0,0 WCS and then
create your hatch inside (hatchscale 1, angle 0)
Same problem in this perfect clean situation?
still a problem?
Upload this sample and upload dwg an your *.pat
Sebastian
ian.mag
Hey @Anonymous
The hatch is probably creating a "wipeout" on the objects. You could go ahead and send the hatch to back.
  1. Select your hatch (you may select similar instances using the right click shortcut menu)
  2. Right click > Draw order > send to back
Forma Design Contest
