Anuncios
Hatch in Solview
Hatch in Solview
No aplicable
Hi! I can't seem to change the hatch pattern in the viewport that wa generated from a solview command. what should I do?Thank you!
0 Me gusta
Responder
277 Vistas
1 Respuesta
Respuesta (1)
cheryl.buck
Autodesk Support
Autodesk Support
Hi @Anonymous,
I see that you are visiting as a new member to the AutoCAD. Welcome to the Autodesk Community!
A hatch can only be applied to a surface in a SOLVIEW view while inside the viewport. The surface will generally need to be flat surface, since Hatch was designed for 2D.
If this does not help, can you provide more information on what area you are trying to hatch, along with the file for the members to troubleshoot?
If a post answered your question or resolved the issue, please click the Accept Solution button.
Likes are always welcome.
All the best,
Cheryl Buck
Technical Support Specialist
Did a post answer your question or help resolve the issue? Please click the Accept Solution button.
If you find a response helpful, consider Liking the post.
0 Me gusta
