Hatch boundry being distort
Message 1 of 9
Dear all
I have a logo make by hatch. It look nice in drawing . But when print it, the LOGO being distort.
Any have any idea how fix this/ please give me some advise ,
Thank you
Replies (8)
Message 2 of 9
Alfred.NESWADBA
welcome @Anonymous!
Some questions:
  • Which driver do you use to print the dwg-file?
  • Which software version and service pack are you using to print the data
  • How big (or small) are the letters in AutoCAD
If you can upload the drawing we can take a look into it.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 3 of 9
ennujozlagam
@Anonymous have you try to set your VIEWRES TO 20000 and see if helps. thanks
Message 4 of 9
this solution is not work. Thank you
Message 5 of 9
Alfred.NESWADBA
do you like to answer my questions (post 2 in this thread) / upload your drawing?
- alfred -
Alfred NESWADBA
Message 6 of 9
Some questions:
    • I use PDF printer 4.0
    • I used AutoCAD LT 2015
    • The text about 10 cm height.
Message 7 of 9
Alfred.NESWADBA
please use the AutoCAD build in option "DWG to PDF.pc3"
That gives is the information about the version, but not the service pack.
Please start command _ABOUT and show us the screenshot from that dialog.
Can you please upload the dwg-file?
- alfred -
Alfred NESWADBA
Message 8 of 9
john.vellek
HI @Anonymous,
This might be the result of using SPLINES to create the outlines using the Fit method instead of Control Vertices.
If you can attach your logo file or send to me privately at [email protected], I am happy to look at the file for you.
John Vellek
Message 9 of 9
john.vellek
Hi @Anonymous,
Have you made any progress on this issue with the suggestions made in this thread? If not, can you share the file with me so I can take a look?
John Vellek
