Hatch area not showing
No aplicable
I've been listing hatches to find their areas, but it doesn't show. There are no lines that intersect or overlap each other. I've also tried deleting all the lines creating a hatches only file. It looks like the hatches simply doesn't have an area, even though they're present... Is there any way i can find these areas without creating new boundary lines and hatches? I got over 100 different hatches in different layers that i want to measure, and creating them all over again would take up way too much time..
Thanks for any help!
Responder
2.976 Vistas
5 Respuestas
Respuestas (5)
Alexander.Rivilis
1. Your dwg-file has many errors (try use command _AUDIT to check it)
2. You can use my free utility GeomProps ( http://www.maestrogroup.com.ua/support/GeomProps.zip ) to calculate area of such hatches.
Result of calculation:
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Expert Elite Member
No aplicable
That looks very functional, but does it exists as an objectARX file? I'm currently using mac..
0 Me gusta
Alexander.Rivilis
Oh. Sorry. There is no version for AutoCAD for MAC. :cara_de_decepción:
Expert Elite Member
0 Me gusta
No aplicable
Hi, this is happening sometimes to hatches. If you need measure total area you can do it a little bit differently with polylines. Recreate hatch boundary and than click on edge curve and you will sea area in properties tab. See video below. I hope that helps.
Best regards,
Ondra
0 Me gusta
No aplicable
Best regards,
Ondra
0 Me gusta
