Hatch appears different in different computers
alginprakashFB6W5
Observer Observer
alginprakashFB6W5
Observer
Observer
I have a hatch pattern which works correctly on my system but in my colleague's system it appears different. I want it to appear as same as my system.
My system
Colleagues system
Thanks in advance.
AllenJessup
Check that you're both using the same PAT file. Default is acad.pat but you may use a custom file. Once you see that the names are the same. Open the PAT files in notepad and compare the definition of the different patterns. There also may be other individual PAT files.
If one file show the "correct" patterns. Copy that to the computer that doesn't show correctly.
Allen Jessup
CAD Manager - Designer
pendean
Community Legend
Community Legend
The one with odd content needs to change the GFXDX12 setting and restart their AutoCAD.
Also turn off LINESMOOTHING and LINEFADING too.
If those don't work, turn off hardware acceleration in their AutoCAD.
