HATA ALIYORUM. FATAL ERROR: Unhandled 0x85762fc. Exception 85762fch.
Layer Properties Manager a tıklayınca   FATAL ERROR: Unhandled Access  Violation Writing 0x85762fc. Exception at 85762fch.
Hatası alıyorum.
Ne yapmam gerekiyor?
pendean
Community Legend
Community Legend
What version of AutoCAD are you using?
Thomas_Stuehle
Hello @Anonymous
Welcome to the AutoCAD forum.
Please check the following points:
  1. In which situation do you get the error? When you describe your steps before the issue appears, it might be easier to understand the situation you are in.
  2. Please do also enter _ABOUT in your AutoCAD command line and share a screenshot of the window that pops up. It will show which version you have installed and if for this version some updates are missing.
  3. Was the function working before or did it happen right from the start after installing the software.
  4. Do you get the same crash in an empty drawing?
Thanks & best regards,
Thomas
Your question got successfully answered? Then just click on the 'Mark as solution' button.
Thomas Stühle
Technical Support Specialist
