Hardware Acceleration Problem
Message 1 of 10
When ever i turn the hardware acceleration on, colours on the screen change. I have attached two screenshots of it. Anyone knows what's the problem and how to fix it ?
Replies (9)
Message 2 of 10
Alfred.NESWADBA
There are two options today:
  • install a newer (or older) graphic card driver
  • wait until Autodesk releases an update with a fix (the inverted colors happened already to some users here so I guess Autodesk is working on that issue)
Sorry for not having better news.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 3 of 10
braudpat
Hello
Welcome to the Autodesk / AutoCAD Forums !
Which version of ACAD exactly ?
And with which SP and Update Packs ??
Regards, Patrice
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
Message 4 of 10
john.vellek
Hi @Anonymous,
I see that you are visiting as a new member to the AutoCAD forum. Welcome to the Autodesk Community!
I am sorry you are experiencing this issue. As @Alfred.NESWADBA, several threads have started recently with this issue.  Can you share some information with me so I can get it to QA?
I would like to know your:
Windows Version (winver)
AutoCAD version (_vernum)
Graphics card make, model and driver version
DirectX Version
Please also take a screen capture of the GRAPHICSCONFIG window.
To give me even more, you could prepare a NFO file for me to examine.
John Vellek
Message 5 of 10
Its AutoCAD 2018 Student Version 22.0.49.0
Message 6 of 10
Windows Version - Windows 10 Home single language 64 bit (10.0, Build 15063)
AutoCAD version - Its AutoCAD 2018 Student Version 22.0.49.0
Graphics Card - AMD Radeon R5 M335 software ver -9.0.0008
Direct X - DirectX 12
Message 7 of 10
john.vellek
Hi @Anonymous,
It appears that there is a newer driver for your graphics card.
My Windows build is 15063.540 which appears to be slightly newer than yours - I suggest checking for updates to your OS.
If you are willing to take the time, I suggest you remove DirectX12 and put DirectX 11 onto your computer to see if that alleviates the problem.
John Vellek
Message 8 of 10
I checked for updates and it shows everything is up to date. Even updated autoCAD to the version released 2 weeks ago. Didn't work !!
Message 9 of 10
john.vellek
Hi @Anonymous,
Thanks for the update. Did you also try removing the DirectX 12 and installing 11 to see if that will help the issue?
John Vellek
Message 10 of 10
So i checked and found a software for updating directX directory. There were some dll files missing. The software filled in those files and now my autocad is working fine.
