Group of objects scaled to actual dimension,
No aplicable
I am copying a previous drawing group from an older file to a new file through copy and paste. It appears that the old drawing is an a viewport but can only be clicked on when in paper space. The drawing itself is in model space. When measured it is the actual length but fits on the paper at the scaled version. When I copy and paste this into the new drawing it is the actual length and not the scaled length that fits. When using the SCALE command it scales everything except the anno dem. tags. Is there a way to scale down the copied drawing so that the anno tags read as the actual dimension as well as when it is measured using the ruler but is small enough to fit on the paper?
0 Me gusta
Responder
411 Vistas
3 Respuestas
Respuestas (3)
john.vellek
Hi @Anonymous,
I see that you are visiting as a new member. Welcome to the Autodesk Community!
To better understand this issue is it possible to attach the file(s)?  I can't tell if you are having difficulty with annotative objects, locked viewports or if something else might be in play.
John Vellek
0 Me gusta
john.vellek
Hi @Anonymous,
If you are still facing this issue, please attach a file for me to examine. I am hoping that I can give you an easy and quick procedure to fix this.
John Vellek
0 Me gusta
MikeKovacik4928
difficult to tell from your description without the actual example.
Possibly the annotation viewing size in model space in not the same as the annotation viewing size in your paperspace viewport
try making them both the same. the model space setting usually defaults to 1:1 if you don't set it.
Michael Kovacik
AutoCAD 2d & 3d (29 yrs)& Inventor (7 yrs)
Manufacturing (30 yrs) Draughtsman
Autodesk Product Design Suite Ultimate 2018
Johannesburg, South Africa
0 Me gusta
