Grip points
Grip points
Hi
When i select grip points, if i zoom out i lose my selection. What causes this?
Example:
If i got a square, and i select upper grip points (while holding shift) to make a rectangle, if i zoom to snap on other object my selection is gone.
Thx in advance.
Replies (18)
Oh its in autocad LT 2019
Alfred.NESWADBA
can't reproduce that. So step by step:
  • I draw a rectangle.
  • I select the rectangle (click onto the object)
  • I press <SHIFT> and click on both upper grips to make them "hot"/red
  • I release <SHIFT>
  • I take one of the red grips
  • I zoom very close to new destination point of the grip I have on my mouse.
  • I click to pick the new position
... following this description, what is different on your system?
Also please make sure, when starting command _ABOUT, that the products exact version information shows "2019.1.2", if it does not then please install the update.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2025
(not an Autodesk consultant)
  • I release <SHIFT>
  • When i zoom i lose the red grips, they become blue again.
Alfred.NESWADBA
have you verified the version information if you need an update?
You might also try command _GRAPHICSCONFIG and disable the hardware acceleration to test this again.
- alfred -
Alfred NESWADBA
vinodkl
zooming in too much also can make the Hot grip deselect.
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
Alfred.NESWADBA
Not on my system, what do I have to do to get that reproduced?
Do you have a drawing so I can see the points you select and the destination area I have to zoom to?
- alfred -
Alfred NESWADBA
Its not that i have to move far, when i zoom out the grip selection is gone.
vinodkl
Same happens to me in video, only way faster. If i zoom its gone.
Alfred.NESWADBA
Ahh ok, that I can reproduce, but this is different to the workflow I showed. Because after making the grips hot, I selected the one I need to have as base grip for the grip-action ... and then zooming does not do anything bad with your grips.
- alfred -
Alfred NESWADBA
vinodkl
Yes its different from the workflow shown. But as told by @Anonymous  the hot grip is deselected when zoom in and zooming out as shown in screencast 🙂 and I don't know why it happens.
It is a different workflow.
But sometimes i have like 5 grippoints (or way more, and yes i know i can stretch command to 😉 ),  if one is out of my screen i cant select it because as soon as i zoom out its gone. Very frustrating.
Alfred.NESWADBA
Yes, but when I try to get that reproduced I had to zoom so close (or so far away) that I can't think about an object with such a big difference between the distances between the grips.
E.g. if I have a few grips that are placed at a distance of 3 or 5 and then one grip at a distance of 500000 ... then yes, then I can reproduce that ... but what type of object should that be?
Anyway, we can reproduce the issue, I don't know any variable that controls this (and I guess there does not exist one for that), disabling the hardware acceleration and/or high quality geometry might help (as it limits the zoom depth before regen is started), you might also try to disable REGENAUTO (which I would hate to with with that setting), but at least I guess that should not happen, so you can create a support ticket and ask Autodesk to repair that.
- alfred -
Alfred NESWADBA
dbroad
Suggestion:  Set viewres to yes and to 20,000.  I believe it has to do with the required regeneration once you zoom too far.  You could alternatively turn off regenauto.
Architect, Registered NC, VA, SC, & GA.
The Diffrence is that i lose the grips after zooming out a small bit. (say a distance of a meter at most)
If i paste the drawing in a new dwg file, its fixed. So maybe thats the easiest solution for now 🙂
Thx all for the help !
dbroad
The reason that the behavior varies by file is probably that the file you're pasting into has a higher viewres setting.  This setting is stored with each drawing.
ara_neresesian
HI
when you "zoom to snap on other point"
1-just click  on the vertex(grip),by clinking somewhere else in the object (rec) you will lose your selection.
2-during selection, don't rush  just click ,don't hold the scrollbar  (because shift and middle click "scrollbar"   will work  as  3d  view rotate) you will lose your selection.
good luck
@ara_neresesian wrote:
HI
good luck
Thats not what happening just watch the video in topic.
