Grid levels from point cloud
richardbuckler
Message 1 of 8
richardbuckler
I would like superimpose a grid of levels on top of a recap point cloud and calculate the level of each grid point.
The level should be an average based upon the cloud points within a 50 x 50 mm square, the gridpoint being the centre of that square.
I am exporting my cloud from Realworks.
Replies (7)
Message 2 of 8
natasha.l
Hello @richardbuckler
You are exporting a point cloud from Realworks & trying to import it into AutoCAD?
Please review "To Attach a Point Cloud to a Drawing".
Please "Accept Solution" if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
Message 3 of 8
richardbuckler
Thanks for replying.
I would like to create gridded points based on say a 50 x 50 mm section from a point cloud.
I use trimble so the cloud comes from realworks into civil cad.
Message 4 of 8
richardbuckler
The grid levels need to derived as an average from a section of the point cloud, not just from single point cloud locations.
Message 5 of 8
pietro.pedone
Autodesk Support
Autodesk Support
Hello @richardbuckler and welcome to the Autodesk Community!
What you're asking is not available in an out-of-the-box installation of AutoCAD, but may be achieved with a custom LISP routine. You may try posting here: AutoCAD Customization Forum
Please let me know if you have further questions and accept this post as a solution if it answered your original request.
Pietro.P
Global Product Support
Autodesk Knowledge Network
Message 6 of 8
ChicagoLooper
OK, so you're running Civil3D, that's good, because you have Recap. I don't know about creating a 50x50 grid, but you can easily take your point cloud to Recap and save it to rcp format.
Once you have rcp format, you can close Recap. Insert the rcp file into C3D. Go to Insert tab=>Point Cloud Panel=>Attach button. After insertion, your rcp file will behave like a block or as an single entity.
Select the point cloud entity and you'll get a contextual ribbon. Go to Visualization Panel=>Color Mapping=>Elevation Tab=>Color Scheme=Apply
IDK about average elevation in a 50x50 grid, it's possible you may, or may not, be able to do it in Recap. Otherwise, you'll have to go to third party software.
Chicagolooper
Message 7 of 8
pietro.pedone
Autodesk Support
Autodesk Support
Hello @richardbuckler , just checking if my or @ChicagoLooper 's message helped you with your question.
Pietro.P
Message 8 of 8
richardbuckler
I need to average a 50 x 50 grid. Thankyou for your answer. I have had no luck with a third party software as of yet either 👍
