Grey Screen Green Lines
Michael.Casey4XXZR
Observer
Observer
Michael.Casey4XXZR
Observer
Observer
I was working and suddenly the drawing went grey except the lines all turned green.  I couldn't get out of it, I had to start a new drawing.  Has anybody had this happen to them?
Replies (11)
pendean
Community Legend
Community Legend
Sorry, we have no idea what you mean, see or what triggered it: next time it happens grab a screenshot of your entire program window so we can see what you see.
TheCADnoob
you may have been able to recover some of the drawing:
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/sfdcarticles/sfdcarticles/how-to-r...
It would be interesting to see if the color changes were actual color changes or due to the a crash.
CADnoob
imadHabash
I suggest to check hardware acceleration from GRAPHICSCONFIG command .
Imad Habash
Michael.Casey4XXZR
Observer
Observer
Okay, it happened again.  Here is a screen shot.
pendean
Community Legend
Community Legend
What were you just doing when it happened? CTRL+F2 and find out.
LAYER command, layer colors change to those?
AND... in PAGESTUP command, is your DISPLAY PLOT STYLES box toggled on?
Any part of that image an XREF?
Michael.Casey4XXZR
Observer
Observer
Pendean,
There is nothing in command history and Ctrl-Z won't undo it. There is only layer 0 and the layer color Is automatic. Object properties are by layer. No plot styles are defined and the DISPLAY PLOT STYLES box is unchecked.
TheCADnoob
This looks a lot like the dwg compare feature... with some setting toggled off.
Can you type commands? if so type COMPARECLOSE and see if it changes anything.
CADnoob
pendean
Community Legend
Community Legend
@Michael.Casey4XXZR So you were just sitting there doing nothing but staring at a just-opened file and poof! it does that?
Michael.Casey4XXZR
Observer
Observer
TheCADnoob,
I think you might be on the right track, I dd the COMPARE command and the result was similar. Not quite the same.
Pendean,
I was editing the drawing when I must have hit some key accidently and the screen shifted. Then I couldn't get back out, I have to close the drawing and go back to the last saved version. If I close and reopen the file it reopens in that same mode.
pendean
Community Legend
Community Legend
Unlike this last time, next time it does it, SAVEAS to create a new DWG file then share that new DWG file here for all of us to see for ourselves.
Why? does UNDO not just revert back right there before that action, so you only lose that action but nothing else?
TheCADnoob
It would be odd for it to start by its self though. Are you using any plugin or custom lisps/macros/scripts/plugins? any chance did you edit the command aliases or perhaps have a customized keyboard or mouse that might trigger it?
CADnoob
