Anuncios
Grey box when selecting 3D solids
xiaohanzhang
xiaohanzhang
When I select a solid I am constantly getting some sort of selecting shadow/extent or something that's quite obscuring; I have attached a picture.
I tried disabling hardware acceleration with no avail.
Is there's any way to turn this off. I am using the default conceptual visual style in version 2017. When using a 2D wireframe style at an angle it looks like selecting grouped objects but if you switch to an orthographic view that grey box reappear like with all the other style.
0 Me gusta
Responder
796 Vistas
7 Respuestas
Respuestas (7)
imadHabash
would you please attache here the CAD file itself ?
Imad Habash
0 Me gusta
xiaohanzhang
FYI, I deleted the two solids I used in the picture. Just use any other solids in the file or create one anywhere. It seems it's particularly prevalent for the polysolid command to behave like this.
0 Me gusta
imadHabash
would you try the follow please:
- use EXPORTTOAUTOCAD command.
- open the new created CAD file.
see if the problem is still and get back to us please...
Imad Habash
0 Me gusta
xiaohanzhang
Tried that with a blank file with just a single polysolid and it's still like that.
0 Me gusta
xiaohanzhang
I have not heard back in a while. Would really like to know just what is going on with this grey fill. Thanks.
0 Me gusta
imadHabash
HI,
would you give us a specific error with attached CAD file,and tell us what exactly the problem?
Waiting...
Imad Habash
0 Me gusta
xiaohanzhang
There is no error per se; it's just that when I draw a polysolid like the one I attached here there is that gray underlay at its bottom when selecting the solid, while if I use existing lines with the polysolid tool the resulting solid has no obscuring gray underlay. I don't think this is normal but can't figure out what's causing this--is this perhaps a bug in 2017? This happens seemingly with all of the default visual style except 2D wireframe.
I've tried ExportToAutoCAD and turning off hardware acceleration but those didn't fix anything.
0 Me gusta
