Graphics issue with autocad
I am working with Autocad with additional 4k monitor. Most of the time half of the screen has some sort of distortion and doesnt work properly. if you zoom out or zoom in it is the same. Sometimes dissapears.
My machine: lenovo thinkbook:
I7-1165G7 cpu
16gb ram
8gb Intel Iris XE graphics.
See pic below for what is happening.
imadHabash
How about starting change your display resolution settings .
Imad Habash
pendean
Community Legend
Community Legend
Have you installed all the AutoCAD Updates yet? ABOUT command should list more than just the basic version number. If not, get the latest from your Autodesk Account Page here https://manage.autodesk.com/cep/#products-services/updates
Then... consider turning off LINESMOOTHING and LINEFADING variables: if still no relief then start GRAPHICSCONFIG command and change the 2D Display Settings pulldown from "advanced mode" to one of the other choices.
If all else fails, then turn off Hardware Acceleration as a last resort.
FWIW go through this set of tips too https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/AutoCA...
Thanks. Its embarassing to say but new drivers sorted the issue.
With old drivers Turning off hardware acceleration helped but I believe you loose performance.
Also lowering resolution is not acceptable as this is why I have 4k monitor 🙂 To be able to use 4k resolution.
Thanks for help
dgorsman
Turning off hardware acceleration is more of a diagnostic procedure than a permanent solution.  If it works, it's a good sign that its a graphics driver issue; either it needs to be updated, re-installed, or possibly even rolled back to an earlier version.
Something else to watch out for is mixing resolutions on displays.  There's quite a few programs that will have problems with running displays of different resolutions e.g. I have one that cuts off the bottom and right side of the window when maximized on either of the two docking port monitors (16:9 displays) but doesn't on the laptop (16:10 display).  Sometimes this can be fixed by not using the laptop display in combination with the external monitors.
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
