Anuncios
Graphics acceleration problem
No aplicable
Hi, All,
I am using AutoCAD 2017 with a CAD work station with a NVidia Quadro K3100M Graphics card, after the recent Windows 10 update I discovered that I could not edit blocks, I contacted an old mate and he suggested that the Graphics Acceleration might be the problem and to try turning Hardware Acceleration off as a temporary fix. This has worked however if I leave it off the drawing graphics are jumpy and curves etc faceted. So every time i want to edit (or write) a block I have to turn off the Hardware Acceleration.(GRAPHICSCONFIG). Can anybody offer any light on this and offer some kind of fix.
Responder
Soluciones aceptadas (1)
10.153 Vistas
15 Respuestas
Respuestas (15)
john.vellek
Hi @Anonymous,
I see that you are visiting as a new member. Welcome to the Autodesk Community!
I looked on nVidia's site and found this to be the current driver for your graphics card. You might try it to see if it improves your performance and block editing issue.
Have you also updated your AutoCAD for hotfixes and updates from your account page or Desktop App?
Please post your results.
John Vellek
No aplicable
Sent from Mail for Windows 10
Hi I installed the latest driver as you suggested, It has made no difference at all,
If I try to open a block I get nothing a blank block editor if I turn off the Hardware accelerator then I get the block in the editor.
What are hot fixes and which one would you recommend.
0 Me gusta
john.vellek
Hi @Anonymous,
You can find the Service Pack and Hotfixes here with descriptions on what they are for. You should also check your Autodesk Desktop App or go into your Account Management page to see if you have other updates available.
While you pursue that can you also type GRAPHICSCONFIG and send me a screenshot of the window that pops up?
John Vellek
0 Me gusta
No aplicable
Hi John,
I guess this is what you want
Tim
0 Me gusta
Alfred.NESWADBA
Just to make sure: is that specific to one drawing or does that also happen when you create a new drawing, draw one line, create a block from that line and open the blockeditor at the end of the block creation.
Also an option: reset settings to default >>>click<<<
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2025
(not an Autodesk consultant)
braudpat
Hello
Are you running with NVidia FXAA graphic Feature = Off ?
Regards, Patrice
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
0 Me gusta
No aplicable
Hi Alfred
I have just opened a new drawing, drew 1 line, made it a block, and then opened the block nothing in the block editor, closed the block editor, turned off the Hardware Acceleration, re-opened the block and there it is in the editor as usual, so to answer your question, yes every drawing, every block, every time, unless the hardware acceleration is turned off.
Tim
0 Me gusta
No aplicable
Hi Braudpat,
Sorry I haven’t a clue, of even where to find that info. I opened the NVidia Control panel The window says
Version 377.11
Quado K3100M
In the left hand panel are tasks.
3D settings:- Adjust image settings with preview, Manage 3D settings or Set physX configuration.
Display:- Change resolution, Adjust desktop colour settings, Rotate display, View HDCP status, Set up digital audio, Adjust desktop size and position & Set up multiple displays.
Video:- Adjust video colour settings & Adjust video image settings.
Workstation:- View System Topology & Set up mosaic
Where would I find a FXAA Graphic Feature
Tim
0 Me gusta
braudpat
Hello from France
1) Please look at the Image ...
 It's a French Windows but I am sure you will find the same on your US/English Windows !?
2) What is your current resolution in pixels (horizontal x Vertical) ?
3) Have you tried to run with: HQGEOM = 0 ?
4) And maybe : LINEFADING & LINESMOOTHING = ZERO ?
Regards, Patrice
Patrice BRAUD
0 Me gusta
No aplicable
Hi Patrice
Greetings from Sunny England,
Thanks for the image , very easy to find.
Yes the FXAA filter is OFF
0 Me gusta
braudpat
Hello
OK and for :
Regards, Patrice
Patrice BRAUD
0 Me gusta
No aplicable
Hi My Resolution is 1680x1050 (Recommended)
I turned off :-  HQGEOM, LINEFADING AND LINESMOOTHING with no difference
Tim
0 Me gusta
Alfred.NESWADBA
Solución aceptada
Have you seen/tried my suggestion of resetting the AutoCAD profile to default?
- alfred -
Alfred NESWADBA
No aplicable
Hi I have re-set AutoCad Back to default settings and the problem seems to have gone away, the only problem now is I cannot use AutoCAD because I don’t recognise it. New ribbon, everything in a new place and all my custom fly-out palettes have disappeared. I am very glad I saved my previous settings!
So how do I get back to my previous settings and keep the Hardware acceleration on!
0 Me gusta
Alfred.NESWADBA
Great to know you have it solved now!
In the same way you modified the user-interface after your first start.
What ever modifications you did just repeat them.
- alfred -
Alfred NESWADBA
0 Me gusta
