I got a Dell Inspiron 7586 with a Nvidia GeForce MX150. My CAD apps fail all the time. Is not a version issue because I have tried AUTOCAD 2018 and 2020 as well. I also tried updates but nothing. I tried turning graphic acceleration on and off but still crashes all the time or works really laggy. When using AUTOCAD I even get blue screens with the next stop code: "VIDEO_DXGKRNL_FATAL_ERROR" If someone could help me I would really appreciate it.
Solved by pendean. Go to Solution.
Blue screen nowadays means hardware defect or driver defect.
If the system is new then take it back to the shop.
- alfred -
did you look up this error message?
its not related to Autocad or Autodesk
>> it only happens when I use AUTOCAD or Inventor.
Well, it happens in 2 different products.
Which other software are you running on your system with such a high graphic usage?
- alfred -
>> those two only
And that's the reason, these 2 are the only ones really stressing CPU + GPU + memory.
So the chance to get errors with these applications is higher than just running word or so.
- alfred -
