Going on my 2nd day of not being able to solve a Super Simple problem
davidsemail916
davidsemail916
I want to make a loft to follow a path.  When I click on path and select it, the loft disappears and I get an Error Code Number 114024.  For the life of me, I can't figure out how to connect the red and yellow circles.
I'm making my own PAPR respirator and this part will be the air manifold.
Any help would be GREATLY appreciated.
Valentin_CAD
@davidsemail916 ,
Just redraw your circles (see attached drawing).
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
davidsemail916
Can you tell me what is wrong with the circle I drew?
I redrew the circles dozens of times and it still won't work?
TheCADnoob
I didn't have a problem lofting... then I think I found a way to duplicate the error... but now I cant get it to behave normally again.... I'm intrigued.
edit: nevermind... i stepped too far back in my undo
CADnoob
Valentin_CAD
@davidsemail916 ,
@Kent1Cooper answered.
https://forums.autodesk.com/t5/autocad-forum/loft-path-not-working/td-p/11983729#
Emilio Valentin
