Global Style Dropdown Dialogue Box and Layout Tab Expansion
I am recommending AutoCAD consider the addition of features as proposed in the attached PDF document.  In summary, I recommend, to expedite productive and promote ease of use, a global dropdown menu that will simultaneously change text, dimension, and leader styles to selected style as created by the user in lieu of changing each individually every time another style is desired for use.  I also am recommending the ability to expand the tab buttons to any desired number of rows and columns so that the user may observer all of the created layouts in addition to the drop down box when the number of tabs created is in excess of the tab bar length.  The intent and hope of this post is a review by the software developers for these recommended improvements.
Thank you for considering these improvements and suggestions.
John
If you are annotating in MODEL space, as it appears that you are, those features are already available as ANNOTATIVE components.
If you're annotating in PAPER space, those features are available as dimstyles.
The multiple rows of layout tabs is a good idea though.
