Glitching cursor in Autocad 2016 empty template (1-6fps)
G'day! I'm a new student of AutoCAD, and have only just installed 2016 (multiple times...).
I have a new pc that's more than capable of AutoCAD, but my problem is that when I open a new template, the cursor glitches as if there is a billion things going on.
Afterburner tells me that the frame rates drop to around 1-6fps when the cursor is over the work space, but the cursor is fine in all the menu's.
I have re-installed several times, my drivers are up to date, and my pc is more than capable.
Any help diagnosing this so I can get to study would be greatly appreciated!
ennujozlagam
try to switch off your hardware acceleration, go to options and see if helps. thanks
Bugger, already tried that one. No luck.
Here’s my PC specs, I shouldn’t have a drama running it.
System Components:
CPU: Intel Core i5 8600K
CPU Cooler: NZXT Kraken X52 240mm AIO Liquid CPU Cooler
Motherboard: ASUS Prime Z370-P Motherboard
Graphics: ASUS ROG Strix GeForce GTX 1080 Ti 11GB
Memory: 2x Team T-Force Night Hawk RGB 3000MHz 16GB for a total of 32GB
Solid State Drive: Samsung 850 EVO 500GB SSD
Hard Drive: Seagate Barracuda 2TB ST2000DM006
chriscowgill7373
Perhaps try an older version if your video card drivers, one from 2015 or 2016, as the software was released in March of 15.
Christopher T. Cowgill, P.E.
Civil 3D Certified Professional
Civil 3D 2022 on Windows 10
Solved it! Wouldn't you believe it, it was trend micro...
