Hello all,
I am experiencing an annoying glitch when I work with two viewports in the Modelspace. As soon as I open a second viewport, the arcs in both viewports become "dislocated": the point where the arc begins and ends is not shown correctly. When I click the arc, the highlighted points are in the correct position, but the arc remains incorrectly shown. Regenerating doesn't solve the problem.
It seems to be just a glitch, if I return to having just one viewport, or if I print the drawing, the problem is not there. But as soon as I open a new viewport, the arcs get messed up.
I attached two images to show the problem:
1. with one viewport: arc correctly shown
2. with two viewports, arc dislocated.
Does anyone know if this is a glitch or if there's a way to fix it?
I am using Autocad LT 2016.
Solved by Alfred.NESWADBA. Go to Solution.
does the same happen (or does it help) if you play with that two switches in the dialog of command _GRAPHICSCONFIG:
- alfred -
That did solve the problem! So it's actually an issue of the video card? Wouldn't have guessed! thanks so much for the help!
Let's say it's an issue in the communication between AutoCAD and the video card driver, updating the driver might help.
- alfred -
