Getting Started: Basics to P&ID, 3D System Layout
edward.wazer
edward.wazer
Brand new to AutoCAD, other than 20 hours of AutoCAD basics via youtube videos. I need to get to a level where I can generate P&ID and 3D system layouts, including instrumentation and plumbing for a small shipping container sized project.
I have generated P&IDs, and designed 3D electrical and mechanical systems previously in SketchUp, so I feel reasonably comfortable with the system design, but AutoCAD software makes Sketchup look like a play toy, so I'd like advice on how to going about learning the software (and which software to use).
Is Plant 3D the software that I should absolutely use?  Or would it be wise at my beginner level to stick with the basic AutoCAD?
What would be a good systematic way to learn?  Are the resources with AutoDesk enough?  It doesn't seem like, and I haven't found much training material for Plant 3D through AutoDesk.
Local community colleges only have 2D AutoCAD, and I don't see Plant 3D courses, except for a few that come up with google searches, such as CTO.
Any advice greatly appreciated.
fatal.error
edward.wazer
Thank you fatal.error.
The linkedin courses you listed are using AutoCAD 2018 or 2019, I'm using 2022.  Have the changes in those 3-4 years been significant enough to make it challenging to learn from a different version?
