I use a gaming mouse that I made a bunch of macros for the buttons for my most used commands. Now that on it's own isn't a ton faster than just typing the shortcuts. Where I gain the speed I believe is that I can be using the commands off the mouse and then my left hand can stay on the number pad to type in distances.
My mouse has buttons on it for: esc, mirror, spacebar, mtext, break, join, delete, move, copy, shift, trim, offset, polyline. Took a while to get used to where the buttons were but not as long as you would think. I made a little cheat sheet and taped it to my monitor for the button locations. I ended up moving the buttons around and put the ones I used more on the easier to reach mouse buttons as it depends on your hand size how your thumb will rest on the mouse. I also tried learning them in tiers and not all at once. Like when I started using it for the first week I really only used the move, copy, polyline, esc buttons as to not overwhelm myself with 13 buttons. I'd need to think about where they were but by the end of the week I just did it and had those 4 down. Next week I added a few more. I mouse with many buttons isn't for everyone. It's just one thing that I do. I used to play games years ago so it's more natural for me. For some people it just adds a layer of confusion and complication that they don't need.
Another thing to get faster is to see what things you do most. If you use break once a day then getting a tiny bit faster at using break isn't going to speed you up very much. If you use move every 15 seconds then being faster at move will really add up over a day. After you find the things you use most then think how can I be faster at these things? What kinds of drawings and software are you using? Post the things you do most as I mentioned and maybe people will have some tips to speed you up. Like me, I used palettes in this way. I put things on palettes that I'm using over and over. When I'm noting up a drawing I have a palette for that. One of it's tabs is 2 different multileaders that go in on different layers, 2 dim styles that go in on specific layers and other things like that. I'm using those things over and over when I'm annotating so having it all set up ahead of time is easier.
You can flip through a few commands with spacebar after you click on a grip. Depending on what you are doing it could help. For me clicking on the grip takes more time than just doing the command and windowing some part of the object to get it selected.
Short version is what things do you do most? Figure out how to be faster at a few of those and your overall speed will go up just by the shear amount of repetition that goes on in autocad.
Nick DiPietro
Cad Manager/Monkey
![](https://0lojpg.bn1301.livefilestore.com/y4mBpjMsxHsiyE90fl7LZ99L9EQYMinMmTq-HRFH9JbCEzkKriwtHkW3fcvHd1Tn83fNmCEOxlu43NSCaM5t5LTUVxzkr2SykXazzjlH6fe8HEZ9J9xESPFwabQTX5LJ7gKPlhZsl0LCsXsW74obCNtIOOvc57pHxbFMWOTgbDVMzABJgwHnVMfJOWjsmiR3b-SgAE5duRw6SWoxUsKOxXgCw?width=220&height=20&cropmode=none)
