Anuncios
Getting a solid loft from uneven profiles?
raybryant1998
raybryant1998
I have two surfaces that are slightly curved, but are the same distance apart at every point. I'm wondering if there is anyway to get my loft between these two surfaces to be a solid.
Thanks in advance.
0 Me gusta
Responder
Soluciones aceptadas (1)
741 Vistas
4 Respuestas
Respuestas (4)
imadHabash
you can try THICKEN command and put a proper thickness value . >> Click <<
Command: THICKEN
Select surfaces to thicken: 1 found
Select surfaces to thicken: Specify thickness <0.1000>: .05
Imad Habash
R_Tweed
Solución aceptada
Check the attached dwg. I used the following steps.
1. surface patch top and bottom open ends
2. sculpt.
schulz8NPAP
Done in Autocad 2008...
Regards
Jochen
www.black-cad.de
raybryant1998
Thank you for the replies. I ended up sculpting the surface using the profile I needed and thickening that surface one inch.
0 Me gusta
