AutoCAD Forum
German dimension style
3 REPLIES 3
ahmed4J6T4
219 Views, 3 Replies
Does anybody know how to convert my AutoCAD to be using German dimension style? (Normal AutoCAD not AutoCAD architecture)
For example:
1- Making the third number after the decimal to be higher (Superscript)
2- To make a length less than 1 meter to be written as a complete number without friction (eg. 50 cm to be written "50" not "0.50"
Please have a look at the attached picture for further elaboration.
Thanks in advance!
3 REPLIES 3
cadffm
in reply to: ahmed4J6T4
Meter/CM is not a problem, you can setup units and sub-units in your dimstyle,
https://help.autodesk.com/view/ACD/2023/DEU/?guid=GUID-6CF94D5C-ADE0-46D8-8D41-C52B22C88603
but there is no real option for the mm5 feature.
Beside of all of ootb abilities, there are tool to fake such a dimension
Like CHBH and similar
Or bigger like Arcibem and some others
Or Applications like ArchDim
- Sebastian -
vladimir_michl
You can try the following settings for the dimension style:
https://www.cadforum.cz/de/hochgestellte-architekturbemassung-nach-din-1356-tip8490
Not 100%, but close.
Vladimir Michl, www.arkance-systems.cz  -  www.cadforum.cz
Kent1Cooper
This has come up before.  I didn't look into them, but check the topics found >here<.
Kent Cooper, AIA
Autodesk Customer Advisory Groups
