Georeferenced images AutoCAD to ArcGIS
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Using AutoCAD 2015, ArcGIS Pro
I have a large number of images that I've georeferenced in a DWG. I'm trying to move them to ArcGIS Pro, without having to manually georeference everything again in ArcGIS. The images keep being placed on my ArcGIS map in the wrong locations, and the problem doesn't seem to be either units or projection.
I have been using the WORLDOUT command from https://www.cadstudio.cz/georefimg to create World Files, then adding the image to ArcGIS.
I have checked that the projections I use are the same in both. I have experimented with changing the map units and drawing units. I have moved the Geographic Marker and the UCS to the projection origin (with false northing-easting and real northing-easting). I've manually converted the units and edited the World File.
Has anyone been successful at this before? How did you do it?
