I'm having an issue where GAP resets OSNAP each time I use it. It's difficult for me to use GAP at all when OSNAP is turned off.
Does anyone else have this issue?
Solved by pendean. Go to Solution.
What variant of AutoCAD are you using? There is no GAP command in plain AutoCAD where you are posting.
But I suspect much like the old DLINE command from back i the day running Osnaps are turned off because they interfere with the function of the command.
Learn to create then use temp override key combos for osnaps if typing them becomes annoying: you can even customize them in CUI command for more than one running at a time if needed.
@pendean wrote:What variant of AutoCAD are you using? There is no GAP command in plain AutoCAD where you are posting.
Ah, that explains it. My version of AutoCAD has a preset configuration. It's likely that GAP is a custom command. Maybe I'll just have to inspect what the contents of that command are. That'll help me troubleshoot.
Thanks for the help!
