hello,
When I try to make fillet between two circles, there is always a gap that I can't fix.
Solved by neaton. Go to Solution.
Hi and Welcome to AutoDesk Forum,
there is NO gap in your file. maybe it's visual issue that can be solved by REGEN command.
The arc in your drawing is coincident to the circles. I notice you added parametric constraints. Did you do this make it coincident because the arc wasn't? When I filleted the other side of the circles and checked the length from the arc end point to the circle center point it is equal to the radius length to the 0.00000000 precision.
It may just be a visual display issue so it appears to not meet.
Nancy
@Anonymous wrote:
hello,
As you can see from the distances to the 8th precision there are no physical gaps between the elements. This is a display issue. Try changing your smoothness to a larger value in Options.
Nancy
